The New York Subway Still Runs On Technology From The 1930s
The New York Subway Still Runs On Analog Technology From The 1930s
Upgrading it is slow and expensive work, but the new systems will eventually allow more trains to run on the same track.
The New York subway is old. You see the signs every time you ride it. The paint on the cast iron pillars is layered like the rings of a tree trunk, and if you removed the ads from the walls, the stations would fool any time-traveler from the 1950s into thinking they were still in their own time.
While the physical infrastructure is clearly ancient, you might be surprised to learn that so is the technology. The system that runs the subway and controls the cars is the same that was used 80 years ago. Literally.
Seguir llegint:
http://www.fastcoexist.com/3050672/the- ... -the-1930s
